20 Most Recent
Epson Stylus Photo R800 InkJet Printer Questions & Answers
Clogged print heads
Sure, you can do it. And it will happen again for long time using. Usually, it happened if using non dyes ink, like pigment ink.
The feed indicator light and
Lights flashing alternately means that your printer's waste ink pad is saturated. It needs to be replaced and reset the counter. To reset the waste ink pad counter you will need a resetting program. You may download it by going to this link:
http://www.divshare.com/download/1140953-256
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles. Try the printer maintenance to clear the printer nozzles. After several deep cleaning attempts and there is no improvements in the print then a new print head is required. A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
I would like to put the cleaning process through,
The print head clean maintenance is usually located in the printer Properties.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
