SOURCE: 1991 Johnsoon 90 HP outboard hard to start, floods after stop
Hi, You did a good job of assessing the problem. It sounds like the float valve in the carb is the likely problem. This would overfill the carb when sitting, flooding the engine and the pressure in the bulb pump would go down as the fuel leaked out. Float valve should be investigated and that should Fixya!
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
SOURCE: 70 hp Johnson hard to start.
could be the choke isn't closed all the way for the first start. Then when warm the motor doesn't need to be choked.
