20 Most Recent Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35 Questions & Answers
Need manual for minn kota mk35
These guys can help you,, home
9/26/2017 1:49:02 AM • Johnson Minn... • Answered on Sep 26, 2017
Batteries 1 and 2 will charge fully, but battery 3 will not fully charge
By reading this.. I am assuming #3 is the crank battery.... Try this.. (from experience) remove all wires (or big terminals) from the battery and see how that works.. I have a 3 bank and use a stand alone charger!! Works BETTER!!!
6/6/2017 3:17:16 AM • Johnson Minn... • Answered on Jun 06, 2017
Minn Kota mk25
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
6/6/2017 3:12:45 AM • Johnson Minn... • Answered on Jun 06, 2017
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals. The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
6/6/2017 3:05:35 AM • Johnson Minn... • Answered on Jun 06, 2017
Why does the red indicator light stay on when I connect to the battery?
That battery may be completely toast, Jacob. Or... it might just be the silly "smart" electronics - an old-style basic battery charger may be able to recover that battery.
8/13/2014 3:06:50 AM • Johnson Minn... • Answered on Aug 13, 2014
0answers
How to wire up 24v minn kota to batterys
if you are trying to wire the batteries for teh 24 volt motor then you need to connect the positive of one battery to the negative of the other battery. then connect the trolling motor to the remaining two terminal of the batteries.
if you are trying to connect the charger to the batteries then each battery should have its own set of wire coming from the charger.these wires should be connected to the batteries in a set not crossed between batteries.
2/24/2011 12:14:51 AM • Johnson Minn... • Answered on Feb 24, 2011
I have a 1978 70 hp johnson with the spark plugs
Hi, with your spark plugs in you are turning the engine over against compression, thats why its harder to turn. The binding noise could be your piston rings, buts its difficult to say without further information. Sorry
7/15/2010 6:51:28 PM • Johnson Minn... • Answered on Jul 15, 2010
I have a 1977 85 hp johnson outboard it started
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
7/3/2010 11:41:52 PM • Johnson Minn... • Answered on Jul 03, 2010
2answers
2answers
1957 johnson outboard 10 hp fuel mixture ratio
https://www.google.com/search?q=1957+johnson+outboard+10+hp+fuel+oil+ratio What is the mix ratio for a Johnson outboard motor? Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio. Feb. 22, 2021
What is the mixing ratio for a Johnson outboard motor? - Mvorganizing.org
1/20/2023 10:22:40 AM • Johnson Boating • Answered on Jan 20, 2023
Owners manual for a 2002 50 horsepower Johnson outboard motor
marine shop---- online search
8/1/2022 6:27:37 PM • Johnson Boating • Answered on Aug 01, 2022
Hi, The tilt / trim runs very slow up & down after motor made minor impact. Motor is a 1998 Oceanpro V6 225. Your advice is appreciated, Thx Ted
With the issue being in both up and down, You may have bent the tilt/trim shaft(s) .. this is a job for a professional!!! sorry..
11/12/2021 4:56:40 PM • Johnson Boating • Answered on Nov 12, 2021
What operates the choke on a 1995 Johnson hj115
Push button ignition switch. Push the key IN while starting it.
11/12/2021 4:52:57 PM • Johnson Boating • Answered on Nov 12, 2021
What is the shift rod length adjustment on a 1988 110 HP JOHNSON ?
CALL YOUR LOCAL DEALER AND ASK THEM . i NEVER TRIED TO REMEMBER SUCH THINGS WHEN I HAD THE SERVICE MANUAL AT HAND
9/5/2021 2:55:05 PM • Johnson Boating • Answered on Sep 05, 2021
40hp johnson 2 cylinder only working on bottom cylinder
Check spark 1st, if ok check fuel line.
8/17/2021 9:17:15 PM • Johnson Boating • Answered on Aug 17, 2021
1984 Johnson 50 horse outboard runs great for an hour or two then will not run to make it back to the dock ???
Service the carburetor. Check cooling system. it may clogged. Run it in a tub and monitor heat buildup. When it stops running, do you have ignition spark? If no then the ignition coil maybe shorted when hot or it may have moved due to untightened screws.
7/17/2021 7:01:15 AM • Johnson Boating • Answered on Jul 17, 2021
98 50 hp Johnson. How can I remove tilt trim?
Check this thread on removing the tilt trim from your 1998 50hp Johnson motor: https://www.thehulltruth.com/boating-forum/490732-1998-johnson-50-hp-trim-tilt-repair.html
8/12/2020 4:22:11 PM • Johnson Boating • Answered on Aug 12, 2020
Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35 Logo
17 questions posted
Top Johnson Boating Experts
NOEL
NOEL
jws1013
Are you a Johnson Boating Expert? Answer questions, earn points and help others
View Most Popular
Johnson Boating
  • Johnson Boating
Most Popular Question
red indicator light stay when connect
  • Boating
