It's going to be your timer. It has points inside. The point the sends power to your selector switch at the beginning of the cycle is burned.
Please ate solution
First, please keep in mind that I'm attempting to diagnose your piece of equipment without even being there and with very little information. Most of the time, not even a model number. Due to this, some times we can only give an educated guess and It seems some do not take this in consideration when rating our solution.
The timer has points that send power to the temp switch. If the timer does not send the power or allow the option, it makes no difference what the selector is set on. The selector works only when the timer allows you an option. Just like you can't rinse in hot. The timer does not allow the option by sending no power to the selector for hot. If you have not opened the console, it will have a wire diagram. Then you will see what I'm saying. May be then i'll get a better rating.
Well maybe yes and maybe no. The timer works for the hot and warm cycles and therefore would seem to be sending power to the selector switch. Is there a separate circuit for each cycle?? I guess what I need is a wiring diagram and maybe, just maybe there is a schematic inside the control panel -- I have not opened that up yet. Heck, I think I can just hot wire to the cold water solenoid and by pass the timer/selector with a toggle switch to allow for a cold water wash. What my wife is now doing is filling the machine on the rinse position with cold water and then dialing in the actual wash cycle she wants to use.
I still wonder if it isn't the temperature selector switch that has "burned" points otherwise why would the Hot and Warm options work.
Hiltonjug,
Thanks for the comment. I did find the schematic diagram and found that the temperature switch was not closing when placed in the cold cycle position. I then used a jumper wire to bypass the temperature switch and the machine filled with cold water and functioned normally. So the problem was in fact the temperature selector switch.
Thanks anyway, John
