Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Jodi Schaefer Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Frigidaire Gallery Stackable that has a screechy dryer
I have a Frigidaire Gallery Stackable Washer/Dryer, Heavy Duty. The dryer is screeching so bad and leaving little black marks on our laundry. What should I do?
Anonymous
Level 2:
Champion:
  • Expert 239 Answers
  • Posted on Sep 03, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
239
Questions
0
Helped
78833
Points
421
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
2answers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
We have a frigidaire gallery, heavy duty, stackable washer dryer. The dryer has stopped spinning. No grinding or anthing just not moving. Belt?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 22, 2010 • Dryers
13helpful
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
3helpful
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
8helpful
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
2helpful
2answers
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
1helpful
2answers
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
