iLO (2 GB) MP3 Player Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pen drive now showing write protected what i do ?
My pen drive is not working when i conect to the computer it's showing write protection my pen drive company name is Kingstone plz help me
laikexpert
Level 3:
President:
  • Master 281 Answers
  • Posted on Feb 05, 2010
laikexpert
Master
Level 3:
President:
Answers
281
Questions
0
Helped
272343
Points
1232
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
I have a 8gb pen drive of kingsten dti series it works perfectly but today my antivirus shows a virus in it and when i try to format my pen drive it shows an error of write protection and after that it...
I am sorry to hear that your USB pen drive got a virus. If the message you get when you are cleaning or reformatting the drive is password protected, the drive is very much finish. I would suggest you to buy a new one.
tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 • Computers & Internet
1helpful
3answers
I have a transcend pendrive wen i insert it it shows drive has to be format but wen i m tryng to format its not formattingl08305
It is possible that the memory was damaged or is infected with a strong virus malware that does a block on detection to the PC. try the same on another PC which has a good protection and if this works there are faults on your port or the PC is infected.
If the drive is still not detected then the memory is faulty even after you try to format on any PC.
The pen drive is showing tht it is write protected nothing can be deleted or moved from the pen drive there is no write protection switch on the pen drive
o.k. have you tried the same pen drive on another computer?
if no, please try this and see if you get the same result?
if yes, unfortunately you may have to reformat your pen drive.
your data on the drive may also be lost.
sorry sometimes these things happen.
My drive is write protected, but I din't do that.dialog box showing remove the write protection. so how to remove this write protection.
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
21helpful
9answers
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
PEN Drive error
right click on my computer after inserting the pen drive in usb, click on manage and select disk managment from left pan, you can format your pen drive by right clicking on it
Write protected pendrive
I protect my pen drive by this software
http://penprotectorenglish.wordpress.com
I hope you can leave protection from your pen drive
Regards
7helpful
4answers
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
22helpful
5answers
Top iLO Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
k24674
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
