20 Most Recent Transcend (589307) Media Questions & Answers
I had the same problem with Windows 10. Go to manufacture on your computer for SD card and reinstall the drivers..it should work fine..remember whenever dealing with Windows you may have to reinstall drivers...
Transcend... | Answered on Dec 16, 2017
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Transcend... | Answered on Nov 20, 2017
Do not use any more and get some data recovery freeware.
Transcend... | Answered on Sep 14, 2017
have a 2gb transcend pen drive.till now it was working properly but now wen i try it says insert an drive into I.the light is glowing and it is getting detected.But i am not able to read the data.anyone can please help me.
Transcend... | Answered on Sep 12, 2017
All your data will be erased & used space of your pen drive will restore to 0 bytes.
Transcend... | Answered on Nov 09, 2015
Try formatting the card and be sure the locking switch is in the off position.
Transcend... | Answered on Nov 03, 2015
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Transcend... | Answered on Nov 02, 2015
Here is the solution,
After you connecting the pen drive go to my computer.
Select the drive of your pen drive. (For eg: E:/)
Then right click on it and select format.
After formatting the pen drive restart your computer.
Then conect it again.
This should work .
My pendrive was also like this when I brought
and formatting solved my problem.
Try this.
my pen drive Please insert a disk into drive problem
Transcend... | Answered on Oct 29, 2015
if u still having the same problem, follow these steps:
1.Insert your pendrive. open mycomputer, note the respective drive showing pendrive.
2. Then go to run and type cmd ( or go to command prompt)
3.It will show like: C:\> or C:\Documents and Settings\UserName>
4.Type the drive name of pendrive as shown in e.g
if drive is h: then type as
c:\>h:
h:\>format h:
it will format and ask for media name, you can give the name of your pendrive.
your pen drive is formatted. Now it will show the free space as 8G.B
Transcend... | Answered on Oct 28, 2015
You can try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Transcend... | Answered on Oct 26, 2015
kya baat hai.........
Transcend... | Answered on Oct 23, 2015
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
Transcend... | Answered on Oct 22, 2015
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Transcend... | Answered on Oct 21, 2015
my transcend pen drive is not showing or hidden
Transcend... | Answered on Oct 20, 2015
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Transcend... | Answered on Oct 19, 2015
see if you can format it if not it is bad
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Transcend... | Answered on Oct 15, 2015
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Transcend... | Answered on Aug 24, 2015
Transcend (589307) Media Logo
379 questions posted
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Mike
ChinthakaJ
ChinthakaJ
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Transcend Electronics - Others
Most Popular Question
pendrive problem
  • Electronics - Others
