Hi, First I would check the fan in the freezer. Listen to see if it is running It moves air to the ref from the freezer Then check to see if freezer control is turned WARMER, which makes the Ref. colder Also this might be a common Defrost problem, Ice is not being melted by the defrost system.The fan can't blow through the coils into the fridge. Take out back panel of freezer to check for ice buildup. The coils should be clean. There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card. Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check fan undernearh Ref in the rear Clean condenser coils underneath .I'm including my article on Refrigerator Repair for your help and convenience.; Please click or copy and paste into browser for Article http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically Thanks for using fixya Leo Ponder imufo2 Please VOTE FOR ME IF THIS WAS HELPFUL
5.5 Cu. Ft. Chest Freezer
Click to Enlarge
Lowest price:$179.00Description: Food
storage will be a snap with this roomy 5.5 cu. ft. chest freezer,
featuring up-front temperature control, storage basket and defrost water
drain.
twist your defrost timer with a screwdriver clocwise till it will click and compressor shut off, check voltage on defrost heater. You should have 120volts.When wait 20 min if compressor start up back and defrost heater is off ...your timer is fine. It can come on early then 20 min....
P.S. defrost heater located on the bottom of the coil, also make sure your defrost thermostat is frozen when you going to check voltage on your heater. Thermostat located on the top of your coil.
The solution to all of the above problems. Disconnect the blue wire from the timer and connect a wire from the white neutral to #1 pin on the timer. As shown the timer operates thru the defrost bimetal
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
possible causes:
bad defrost timer
bad defrost heater (in freezer)
bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
