20 Most Recent
Magic Chef MCBR445S1 Stainless Steel Compact Refrigerator Questions & Answers
I bought a new magic
the step you were not aware of is that the unit needs something in the compartment so that the liquid gas can boil off and produce cold
normally a jug of water will do the trick
if the water doesn't feel cool/cold after 1 hour , call the technicians for a warranty check
Not cooling
Check if compressor is starting and the click start of the compressor starting. After that refrigerator should have humming vibration. If yes then check the thermistor or replace THERMISTOR. Actually thermistor's job is to sense the cooling temperature. If THERMISTOR is faulty then ice formation will not happen. Once desired temperature reaches then thermistor activates relay attached with compressor for autocut.
