2002 Dodge Grand Caravan Logo
Posted on Aug 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is no fuse box under the drivers side and i have no power t
I plugged in the air pump and the key activated cigareete lighter outlet and the radio does not work. I need to know how to fix this problem. I need my radio.
Anonymous
Level 2:
  • Expert 36 Answers
  • Posted on Aug 21, 2009
Anonymous
Expert
Level 2:
Answers
36
Questions
0
Helped
13558
Points
109
Probably need to replace a fuse which I believe is slightly above the pedals and to the left a little.
Anonymous
Level 1:
  • Contributor 4 Answers
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1094
Points
10
Should just be a fuse blown. Check your manual in the index under fuses and check the one for the radio. Should be on drivers side or under the hood.
Mike Deemer-White
Level 2:
  • Expert 96 Answers
Mike Deemer-White
Expert
Level 2:
Answers
96
Questions
0
Helped
54772
Points
300
Check the engine compartment. It's definitely a fuse that has blown.
3answers
Where is fuse located for horn (driver) 2004. Gmc envoy
If possible, pull the horn relay, use jumper wire on switch side of relay, right side in diagram. If the horn sounds, it's not the fuse. Sometimes these diagrams don't post, for some reason? good luck
1helpful
3answers
Where is 2007 DTS CADILLAC CIGAREETS LIGHTER FUSE LOCATED
Yours is under the back seat. The panel lid is marked for the fuses.
1helpful
12 volt in dash power outlet 2001 dodge dakota
The power outlet uses a 20amp fuse marked D in the box near the battery.
The cig lighter uses a 15amp fuse in the inside fuse box.
5helpful
2answers
The accessory power supply, not the cigarette lighter, isn't working. Which fuse do I replace?
The car makers sometimes do not list power outlet, the best thing is to test all the fuses, let me see if i can find a fuse diagram for your 2000 sienna,..................okay fuse is labeled as power outlet and is in the inside fuse box not the engine compartment fuse box, here is a diagram of the fuse box i circled the fuse ,the fuse box is located on the driver side under the left side of the cluster, good day.8_27_2012_5_55_17_pm.gif
3helpful
There are 2 lighter plugs on my yukon. the one on the drivers side stopped working. The other, on the passenger side still works. Pulled every fuse in interior fuse box by drivers side door. None look...
{: ) There are two fuses that protect the front IP power outlet or lighter plugs. At the underhood fuse block, labeled CIG LTR 15amps and AUX PWR 20amps. See red arrows on diagram below.
The fuse on the driver side door fuse block labeled AUX PWR2 20amps protects the rear lighter plugs.
2answers
My power outlet in my 1995 Ford Mustang has stopped working. I replaced the fuses under the hood of my car with 20 amp fuses for the issue and still the power outlet isnt working. Is there something wrong...
first un plug the lighter use a test light ground 1 end and see if thare is power ive seen alot of the lighters be bad for what ever the reason if you have power to the wire with the key on its the lighter if not the best thing to do is put in a new wire to the fuse box that comes on with the key thare are always extras in the fuse box
2answers
Cigareete lighter fuse 2005 Montans SV6 where is it
To access fuse panel you are looking for that holds the lighter fuse open the passenger door and look on the right end of the instrument panel (dash) There is an access panel that just pulls off. Pull it off and there are your fuses.
3helpful
3answers
Cigarette lighter quit working - is there a fuse that I can check.
I suggtes check the position CIG LTR for Cigarette Lighter. The underhood fuse block in the engine compartment on the driver's side of the vehicle near the battery. Lift the cover for access to the fuse/relay block.
To remove fuses, hold the end of the fuse between your thumb and index finger and pull straight out.
Also, in this link could donwnload the Owner's Manual for the 2005 Chevrolet Tahoe.
Hope this helps to solve it (remember to rate and commene this answer).
2helpful
3answers
Where is the fuse for Cigarette Lighter in 1998 Plymouth Voyager?
the main fuse box is usually under the hood,you may find a small fuse box under the dash as well.....hope this helps.....cheers
2answers
I can't find the fuse for the 12v power outlet on my 1999 Dodge Ram 1500
up under the dash on drivers side. Not under the hood
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
