Engine revs fine in neutral but stalls when placed into forward
Hi take the prop off see if there is anything /string/ between the hub and the housing check oil lvel in g/box /is gear box nice and free if all is ok try it in ware with just a small amount of choke
drain /empty fuel out replace with fresh /correct oil mix
check /change fuel filter/air filter
warm engine up check idle mixture ajustment/tick over speed
increase idle speed slightly/7/800 rpm
hope this helps merlin v 12
