Washing Machines Logo
D
Dianne Posted on Jun 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the washer not changing the cycle from wash to rinse
Dw Wooten
Level 2:
Sergeant:
  • Expert 227 Answers
  • Posted on Jun 24, 2019
Dw Wooten
Expert
Level 2:
Sergeant:
Answers
227
Questions
Helped
115757
Points
551
Good be washertime ate control board you may want call a techcian to help solve your problem
5 Related Answers
A
Anonymous
  • Posted on Jul 09, 2008
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Dec 25, 2008
SOURCE: Washer quitting on rinse cycle
no cold water ,,lid switch or defective
Anonymous
  • 686 Answers
  • Posted on Apr 09, 2009
SOURCE: kenmore washer,mod# 110 26292694/wash cycle only
CHANGE THE LID SWITCH
Anonymous
  • 1865 Answers
  • Posted on Apr 25, 2009
SOURCE: cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Anonymous
  • 1185 Answers
  • Posted on May 23, 2009
SOURCE: washer won't drain after rinse cycle
If you lay the drain hose down into a bucket does water come out fairly quickly?
If so then it is not a blockage
You may have a coin or other small object in the pump which stops the impeller turning so no pumping action
Only solution is to check if the pump is free to turn either via the filter opening or taking the back panel off (Remove power before doing so ) and turning the pump by hand (there will be a fan blade on the end which is connected directly to the impeller.
If that will not turn very easily then you need to take off the hoses and check what is happening with the pump unit
2answers
My LG washer stops in rinse cycle. Have to unplug restart and set to spin only to finish.
If the washing machine does stop at the rinsing cycle and will not continue , It could have something to do with the machine's timer not working correctly . If the timer is broken or is not working it will have to be replaced to make sure that the machine can be able to run through the rinse cycle again.
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Washer stopped before spin and rinse cycle.
you nead to bay pas the door switch. orb replace
it.
2answers
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
Maytag keeps washing
Washer with O.C.D Darn, sounds like your timer sequence board has a problem. don't spose a warrantee issue?
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Top Washing Machines Experts
john h
