Http://www.youtube.com/watch?v=9MlWAJ0Y0Yg
watch it and bam solved
The keyboard failure error message comes , when the system motherboard is not able to detect the keyboard. This could be because f a fulty keyboard or motherboard.
Remove all cables from the back of the system tower including the power cord
Press and hold th epower button in the front of the system tower for 10 seconds
Reconnect the power cord , monitor ,mouse, if you are using a USB keyboard connect it to a different usb port.
Power on the system and check for the error message .
You can also check if the keybooard is working fine , buy connecting it to a good known system.
Thanks for using FIXYA
Proton
Go to bios setup, load defaults first. enable usb keyboard support and usb mouse.
When powering on the F2 key will get me to Bios Setup, F8 key will get me to Safe Mode, and F12 key will let me change Boot Device. Everything is normal when up on XP operating system. If I reboot, None of the mentioned function keys work. Instead I get a message of a "Keyboard Failure", but system will come up OK. But, on the reboot, I want to use one of those function keys.
I have a DELL 2400 Dimension running Windows Home XP. I am using a Logitech EX-110 (Combo keyboard & mouse)
This seems very similar to another write up on this site.
Any ideas? Don't tell me to toggle the keyboard. I tried it with no positive results
