Lands Phones Logo
Carole Blackley Posted on Jun 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi have put a new battery in handset & it tells Me it is searching & says it is out of range the phone & base are in same spot for same for awhile
Tracy
Level 3:
Master:
  • Master 581 Answers
  • Posted on Jul 01, 2019
Tracy
Master
Level 3:
Master:
Answers
581
Questions
0
Helped
145294
Points
1750
I agree with charging the battery all the way..But you could have moved your sim card..Make sure it completely in the slot.Also turning off the phone and power it back up.If that don't work go to settings and mobile networks and check if you on a mobile network
Cathann Smith
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 42 Answers
Cathann Smith
Expert
Level 2:
New Friend:
Night Owl:
Answers
42
Questions
Helped
13087
Points
104
It probably needs to be charged more that is all. It usually needs a good 8 hours to fully charge. Even with new battery it needs to charge before using.
5 Related Answers
Anonymous
  • Posted on Aug 28, 2008
SOURCE: searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
gorbuz
  • 5 Answers
  • Posted on Nov 04, 2008
SOURCE: bought new phones kxtga110ex and want to register handset from kxa141es
I can send you a manual. Just email me on [email protected]
Anonymous
  • Posted on May 19, 2009
SOURCE: i want to add an additional handset to my vtech phone...the new handset is "searching for base" and requests a 15-digit number which is suppose to be on the base--there is no 15-digit number to input.
The 15 digit number shoudl be on a sticker on the bottom of the base unit.
Anonymous
  • Posted on Jun 07, 2009
SOURCE: bt graphite handset states out of range but is on base
the manaul states that by resetting the phone should solve this. In my case removing the batteries from the handset for a couple of seconds seemed to work just fine.
Regards
Anonymous
  • Posted on Oct 09, 2009
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Thomson Skype phone CE21878GE5-A - OUT OF RANGE
Make sure the aerial is extended, most have one on the base unit. Resetting is achieved by remove all the batteries and mains plugs for an hour.
How do you reset a cordless landline phone?
Resetting a DECT phone.
  1. Disconnect the main base unit from the power supply and the telephone line.
  2. Remove the batteries from all of the handsets for approximately 1 hour.
  3. Re-insert the batteries into the handsets and power up the base unit.
https://www.google.com/search?q=CE21878GE5-A+-+OUT+OF+RANGE
Videos here
Put a new battery in my phone, now it gives me an out of rane message. how do I fix this?
I don't know what model it is but try these:
1. Check the main base is powered up!
2.Take out the battery again and edit a few mins and return it. Place the handset on the base. Now try.
3. If that didn't work you are probably going to to reassign the handset to the base. Check your manual on how to do that.
2helpful
2answers
Handset says searching
Searching means its searching for a signal. If the phone cant contact the base it will say searching. Make sure the handset is in range of the base and the base is connected to the power.
3helpful
Why is handset reading out of range? OR searching?
THAT HAPPENS WHEN YOU DROP THE PHONE TOO MUCH.
THE SOLUTION IS TO TURN OF THE BASE FOR 2 MINUTES.
THEN REMOVE ALL THE PHONE BATTERIES. ALL OF THEM
WAIT FOR MINUTES,
PUT THE BASE BACK FIRST, PUT ALL OF THE PHONES BATTERY BACK
PRESS THE RED BUTTON, YOU WILL SEE THE "OUT OF RANGE RANGE" MESSAGE AGAIN.
IGNORE IT AND PRESS THE GREEN BUTTON. HERE YOU GO.
MAKE SURE TO CHARGE IT AFTER THIS.
PLEASE RATE IF THIS SOLVED YOUR PROBLEM
3helpful
My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
1helpful
Motorola MD400
Take battery out of handset for one minute.
Unplug base unit (power and phone line) for one minute.
Plug base unit back in (power and phone line).
Put battery back in handset. Place hangset on base for
one minute. This got my phone up and running.
I had no battery power in the base unit, but if I did, I think
you have to remove those as well.
31helpful
5answers
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
