Go to computer than click on Sansa e260 - Click on PPI NAND - Click on PLAYLISTS - Create a new FOLDER - Give your playlist a name - than put the music in it.
Sansa MP3 players have 2 modes, MTP and MSC. In order for playlist to show up properly on your player it must be in MTP mode. First, go to settings then USB mode or just mode( depending on the player). then choose MTP. Once it's in this mode, connect to you PC. Open Windows Media Player and go to the library. Right click on the song of your choice then go down to "add to" then click on additional playlist. Type the name of your songs and click ok. Right Click on the next song, click on "add to" then click on the name of you playlist. Continue this until you playlist is complete. Click on the Sync tab at the top and then click on sync settings. make sure "sync device automatically" is checked off. scroll through the large white box and only check off the playlist you want on the player. Click ok and the playlist will start to sync to the player. Once complete, disconnect the player select music then scroll down to playlist and you will see the name of your playlist...
I hope that helps
Please rate accordingly
Thank you
Computerrep
connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
Check the firmware upgrade for the c200 series on Sandisk's website (and the forums) - I can't remember exactly how it goes, but either the firmware upgrade makes playlists display correctly, or it prevents them from dispalying correctly - I can't remember which
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376.
Should you have any problems after updating the firwmare on your device you can contafct me and I will be more than happy to help you
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
The Sansa m200 series can only create playlists in MTP mode. on the menu go to settings>USB. There are two options MSC and autodetect. Once in autodetect your sansa should say MTP when connected to your PC. In this mode you should be able to add playlists without any trouble.
Hope it helps
please anyone help me
