Will Sony laptop Vaio VGN-S360 support 2GB RAM?In other words can I use 2x1GB RAM for my VGN-S360. The spec indicates that this laptop will support RAM only up[ to 1GB in total.
Thank you for the response. Any particular reason why you saying that it will not support 2GB of RAM (i.e. have you tried)?Thank you for the response. Any particular reason why you saying that it will not support 2GB of RAM (i.e. have you tried)?
You can't post conmments that contain an email address.
All Mother Boards are made to handle a certain amount of RAM. If the manyfacturer says it can handle 1 GB (as you have mentioned above) then you cant put 2 GB on it. Why should a manufacturer claim less for his product?All Mother Boards are made to handle a certain amount of RAM. If the manyfacturer says it can handle 1 GB (as you have mentioned above) then you cant put 2 GB on it. Why should a manufacturer claim less for his product?
Sony VAIO VGN-FS 760/W supports PC-3200 400MHz and PC2-4200 533MHz DDR2 RAM Expandable up to 2GB. Please make sure that both RAM Chips are according to the above specification, compatible with yout system and both sticks are the same (make & bus speed). Try using one RAM at a time and swaping RAM slots to see if the amount of memory is shown correctly. Memory is not recognized only when it is not up to the specifiction. If the RAM sticks are ok, the system shoud recognize them.
Let me know if any further clarification/ assistance is required. Good Luck! Hope this helps! CreativeTECH
1.
Most likely they sit on the same Connector back-to-back. So hat each RAM module faces each other after installation.
2. The second compartment should be checked according to the manual.
