To enter service mode press the status key and enter 1087 and then 1087 again. But to login for system settings the User Name is 4000 and the Password is 4000.
The copier is equipped with a maintenance function which can be used to maintain and service the machine.
Lower you will find a photo with the steps for entering maint. mode.
Also you can find a link with all the maint. items in the maint. mode.
for kyocera 1820LA look if it's works: turn on your computer by opening the top door previously. you press the menu system. you fit in service configuration and enter. press the START and # then enter. done this in configuration service runs a new submenu called maintenance mode. until it happens you should try this. when you enter maintenance mode out and then back. browser to locate yourself U163 code. you give execute.
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
