Computers & Internet Logo
a
anthony buono Posted on May 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony vaio pcg-grv550/pcg-8f1l lost bios password tryed pw # from web did not work is there a button battery
I see a 2.4 battery i unpluged it still cant get pass password help please thanks
Joseph Wright
Level 3:
  • Sony Master 1,729 Answers
  • Posted on May 01, 2019
Joseph Wright
Sony Master
Level 3:
Answers
1729
Questions
Helped
455417
Points
5127
Either wait a day with no power (and the battery removed) or short across the leads to the battery connection (with no power and the battery removed.).
2 Related Answers
Mesmo
Canaan Hoffman
  • 164 Answers
  • Posted on Oct 20, 2008
SOURCE: Bios password problem Sony vaio PCG-7Z2L
What type of bios Award,Phoenix, AMI, Etc?
maxcarson
max carson
  • 7627 Answers
  • Posted on Apr 27, 2013
SOURCE: Resetting sony vaio bios pass
Contact Sony for a one-time BIOS password would be your last hope.
2answers
We cannot remember the BIOS password for a Sony pcg7f7p laptop.. how do we reset? cant locate the BIOS battery on the motherboard
Last 7 digits of the serial number for the Sony PCG series laptop can be entered at the web page shown to generate a new code.
https://bios-pw.org/
For other models, with VGN shown below, after entering the wrong password 3 wrongl times, a number appears.
[SONY]
Sony PCG series can be unlocked by last 7 digit from serial number
Sony VGN-A series after 3 tries it generate random xxxx - 4-hex code
Sony VGN other series after 3 wrong tries it generate random 5x4 code, do not turn off laptop until get master password
For example: Sony VAIO VGN-SZ22 [268r-dkxj-38j7-9j2k] password: 33637436
If you enter the number in the web site below, it generates a code for you to use.
Let us know if this works for you.
RESET BIOS PASSWORD
To reset the Bios password try removing the laptop battery unplug the power supply and hold down the power on button for 30 seconds, if this does not work remove the bios battery for 1 minute
1helpful
3helpful
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
1helpful
My sony VAIO PCG-731L has a problem and I need a bios password to unlock it. Can anybodyhelp me?
With the last 7 digits of your serial number visit http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php and for $20 they will supply you with the bios master password for your Sony laptop that will clear any bios password set. They guarantee it to work or your money back. They do most laptops like Dell, HP, Compaq, Sony, Samsung, Fujitsu, etc.
NEED TO CLEAR BIOS PASSWORD
Hi
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
CmosPwd - Cmos password recovery tools
Please let us know if it works
1helpful
How to reset bios password on sony vaio laptop?
Please open you vaio laptop from bellow instruction link.
http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
Follow step 14
You can manege the idea about CMOS battery.
http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
Follow step 11
But this is your actual model
http://www.insidemylaptop.com/?s=PCG-K33+PC+Notebook
Just remove the Cmos battery And wit 2 minutes again fit the battery .Your password will be soon reset.
Hope it will help you.
2helpful
I need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
2answers
How Do I Boot A Sony VAIO PCG-Z505LS model # PCG-531A?
The BIOS one can usually be eliminated  by disconnecting the battery and shorting the terminals, if necessary, then plugging the battery back in.    The administrator pass work can sometimes be gotten around by pressing the F8 while loading,then changing it.   The most undesirable option is to reformat and buy another OS.   Sorry for the hard time.
1helpful
Lost password
remove the bios battery from the mainboard for about 45 seconds. if this is a password set in the bios it will reset it to blank. This will require unplugging the computer and removing the case or side of case. the battery will be easy to spot if not covered by something else, it looks like a large watch battery and just has a little clip holding it in place..
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
