Customer was given tablet and tried to clear up space and deleted windows folders and emptied recycle bisn. I was able to get his license for Windows, and reinstalled. Several Drivers not found with Device Manager. I purchased a program to help with getting drivers....big mistake....that didn't work. Trying to get money back. we'll see how that goes. I knew better, but.......
SOURCE: unable to install AL1916w lcd driver in xp
i buyed the new al1916w lcd monitor ,i tried to install the driver for it.
i also downloaded the driver from acer site ,when i looked in device manager ,i found two plug and play monitor
plz check this link
<a href="http://imageshack.us"><img src="http://img151.imageshack.us/img151/2717/48550554nr5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
then i selected update driver from the right click and selected the folder wherethe driver was stored ,after searching windows cannot find the drivers.
i am sure that the folder has the driver downloaded from the site.
check this link
<a href="http://imageshack.us"><img src="http://img100.imageshack.us/img100/71/28697132zh8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
now how can i install the lcd monitor driver?
any other method?
hi friend
here is 24 hour online service tecnision link tell your problem to him i shoure he will guide u give a good sujesion here is link for hap 24 hour online sevice technision
http://welcome.hp.com/country/us/en/contact/chat_1.html
SOURCE: Unable to Install Drivers
Try to re-install your motherboards chipset (inf) driver.after that try to install your mp3 player.
Thanks
SOURCE: No audio device found
Download Driver Cleaner Pro v.15 from the link. Also, download, and save on your desktop, a clean version of your Sound Card drivers. Run DCPv1.5 and remove all of your audio drivers, plus any possible problem drivers (i.e., if you installed generic drivers to try and get your card to work). After you uninstall, reboot, install your downloaded drivers and reboot again. This should fix your problem, if not please post an update to this thread and I'll continue troubleshooting with you.
SOURCE: no audio output device is installed!!!!help
A lot of the newer audio chipsets (especially in laptops) use Microsoft's Universal Audio Architecture (UAA). Windows 7 and Vista don't need a separate driver, but XP does. So you need one of Packard Bell's combo driver packages like this one:
http://support.packardbell.com/uk/item/index.php?i=6944060200
There are a lot of different EasyNote models, so if this isn't the right package for your computer, enter your serial number in the support site to find the specific downloads.
The scroll on your laptop is controlled by the trackpad installed on the system.
If you are having problems with the scroll on your laptop's trackpad, there is something you can do before you take it into a computer repair shop.
Updating the driver to the trackpad will enable the scroll if it is not working at all.
Once the driver is updated, your scroll should work again.
You can access the driver through the Device Manager on your laptop.
Click the "Start" button, then click the "Search" option.
Type "Device Manager" into the search bar and press the "Enter" button.
Click on the "Device Manager" icon from the menu, then scroll down to the "Track Pad" icon on the left side of the screen.
Click on the icon, then click the "Driver" tab at the top of the window. Click the "Update" driver option from the window.
Wait for the new driver to install on your computer.
This should take about two minutes to complete.
A window will appear telling you that the driver has been installed.
Put your fingers on the touchpad to move the mouse around on the screen.
Hope this helps.
