Car Audio & Video Logo
G
Gary Feuerberg Posted on Apr 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the ribbon cable for the Panasonic 3-disk player, model SL DH66
This cable connects the CD changer to the amplifier. My unit is from 1993.
Darrin P. De May
Level 3:
Master:
  • Master 665 Answers
  • Posted on Apr 23, 2019
Darrin P. De May
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
153463
Points
1951
Just saw an entire SL DH66 on eBay for $24.99 untested. If you really love yours, buy that one for parts:
https://www.ebay.com/itm/Panasonic-SL-DH66-CD-Player-Deck-Stereo-UNTESTED-SOLD-AS-IS/163598444405?hash=item26173a2775
I need the ribbon cable for the Panasonic 3-disk p - 4_23_2019_10_02_25_pm.jpg
5 Related Answers
Anonymous
  • Posted on Oct 09, 2007
SOURCE: PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Anonymous
  • Posted on Jan 03, 2009
SOURCE: Panasonic CD PLayer SL-CT520 Rechargeable AAA Batteries
Hey this is RaulFixall. You can fix this problem by naking the batteries, I'm mean by taking apart the plastic that cover them. You'll see that the led charging will turn on.
drife
  • 135 Answers
  • Posted on Jan 15, 2009
SOURCE: locate the cable from the Audio system to attach a CD changer
The cable is optical and is runs back to the left side of the boot or trunk i dont think it will work with the ipod   D
wayne chamberlain
  • 89 Answers
  • Posted on Mar 13, 2009
SOURCE: CD changer...doesn't play...says ''no disk''
Yes Dust can cause the problem.
If you want to try cleaning the laser optics:
1. Unplug the unit and remove the cover.
2. Locate the Cd mechanism and you should see the tray where you would normally insert the disc. Look for a glass lens about 1/4 inch in diameter ( usually a blueish tint)
3. With a cotton swab dipped in a little isopropyl alcohol (any pharmacist should have it and it is very inexpensive ) Clean the lens. You do not need a lot of alcohol and any excess will quickly evaporate.
4. Put the cover back on and give it a try
Anonymous
  • 3 Answers
  • Posted on Mar 14, 2009
SOURCE: I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at: [email protected]
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
2004 GTO will not eject CDs, says CD mech error.
I just had this happen the other day. It completely jammed up. I ended up having to remove the radio and disassemble the upper changer section to get the disks out. The problem with mine was that one of the disk trays broke and jammed the mechanism. I ended up gutting the changer and and reassembling the radio and installing it in the car to use the AM/FM function. I'm currently in the search for a new radio to swipe the CD changer off of since even radios that you do not have the security code for will work as the coding is in the radio section and not the CD changer. The changer attaches to the top of the radio with 2 T8 and 4 T10 screws and connects with a ribbon cable between the two modules. You'll see the ribbon cable when the top CD changer mechanism. Be careful removing CDs this way as if the player's rotating assembly is not retracted, it is very easy to scratch the disk. Unfortunately I lost a Velvet Revolver disk this way. Good luck! If you are on one of the the big boards I go by TR GTO on both if you need to contact me and I'll walk you through it.
1helpful
Cd "swallowed" by changer unit
clear any obstructions, clean unit inside, be careful.. Tray can bind up due to dust and lint. Try disk one only and play. Go through all 5 separately and try and see if they all swallow the disk or could be just #3 example. use dust away to clean unit. be careful not to touch laser.
3helpful
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Power cord for Techniques SL-PD9 CD Player
Fairly common cable - I have several for various chargers for cameras, camcorders and laptops. You can get them at Radio Shack
Compatible units
Hi check if your changer connects to the amplifier with a single ribbon cable. if this is the case then the unit is not compatible with anything else.
If it has its own mains cable and a couple of RCA connectors on the rear, then anything should be fine
6 cd changer in 2001 ford expediation
If the unit will not accept or eject any disks, this is a relatively simple fix. Remove the unit from the vehicle. There are 4 T-9 torx screws on the side of the radio. Remove them and slightly lift the CD mechanism from the radio. There are 2 things that need to be unplugged before you can separate the 2 pieces. The 2 wires simply unplug from the bottom of the cd mechanism. The ribbon cable is locked into the socket, you need to grab the lock and gently pull it away from the circuit board. When unlocked the ribbon cable will simply fall out of the socket. Look through the front of the changer mechanism, are there any disks that look out of place? Gently lift the trays to inspect the disks, if one of the disks is too far back you need to get it into place. Reassemble the deck and see what happens.
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
