20 Most Recent
Technics SL-PD687 5-Disc CD Changer Questions & Answers
I have a technics 5 changer CD player, model#
You ever get a solution to this, mate?
I have the same freaki'n issue with mine all of a sudden. Suspect the power supply's not delivering enough power to rotate the spindle-motor anymore, cause if I take this motor out and connect it to a 1.5V battery, it runs...
let me know if you've found the solution please on: tobie dot steyn at gmail dot com.
1/6/2023 9:05:35 AM •
Technics...
Answered
on Jan 06, 2023
I burned a CD on
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
1/18/2015 1:53:16 AM •
Technics...
Answered
on Jan 18, 2015
We cannot use this because
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Take care.
2/3/2011 6:36:21 PM •
Technics...
Answered
on Feb 03, 2011
Open, closes and rotates the cd compartment, endless...
If there's a disk left over inside, It's stuck in the drive hanger, and should be removed else the changer can't put it back in it's right slot. Open the machine and check for any CD's still inside.
If not, could be that the small sensore (to the left of the head assembly (just before the drve (upside down)) is dirty or messed up.
Try cleaning if.
3/25/2010 11:49:56 AM •
Technics...
Answered
on Mar 25, 2010
Cds
Could be the power supply not supplying enough juice to the spindle motor. Make sure it's not plugged into a "multi-plug" adapter.
Could be the spindle motor as well, or the disk sensor.
Let me know should you find something else...
3/25/2010 11:45:19 AM •
Technics...
Answered
on Mar 25, 2010
I have a Technics 5 disc CD player. The loading
Unplug the units power, unscrew and remove the top. it has 3 screws on the back and I believe 2 in each side. Look to see if anything such as a CD is jamming or preventing the tray from opening.
If there isn't something like a CD physically blocking the door mechanism then the issue could be anything from a slipping drive band a dead motor or something has gone wrong with the mainboard.
The "expected" life of an audio component is 5-9 years. If its past 3 years old its generally not worth repairing as 1 hour labor and a motor for instance would cost you more than the cost of a new unit.
Hope that helps
12/30/2009 4:18:13 PM •
Technics...
Answered
on Dec 30, 2009
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
12/26/2009 6:51:27 PM •
Technics...
Answered
on Dec 26, 2009
Distorted sound when playing CD
have you tried cleaning the cd lens ?insert a lens cleaning cd , follow the voice instructions and your cd player will be as good as new.HAPPY LISTENING.
2/7/2009 5:31:45 PM •
Technics...
Answered
on Feb 07, 2009
