LG has rather finicky icemakers that are usually computerized. There are magnetic pickups that tend to not read right causing icemaker failure.If it will cycle but not fill then this is most likely the issue. Without knowing the model#, I can only guess but as long as you have proper temperatures then the icemaker will need to be replaced.
You can unplug the unit for 2 minutes then plug it back in for a hard reset
SOURCE: ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
SOURCE: I have A GE Profile frige (PFSS9PKYASS) with a
are you sure you replaced with the right filter? how old is it?
FixYa Support
there's a heater on the ice maker,if the ice isn't coming out i'd have to say you have a bad ice maker
HI
Will dump manualy?
Not in Auto
Check Ice Hopper For a Stuck Switch
