20 Most Recent LG LSC26905TT Side by Side Refrigerator Questions & Answers
I not sure what kind of reset button you need. I don't see one in these diagrams. But let the whole thing defrost.
https://www.appliancepartspros.com/parts-for-lg-lsc26905tt-antclga.html
LG LSC26905TT... | Answered on Jan 25, 2019
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
LG LSC26905TT... | Answered on Oct 21, 2018
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
LG LSC26905TT... | Answered on Sep 28, 2017
Handles has a small allen screw in the inside part , and to make doors close it has to be higher at front , someof them youcan adjust front legs
LG LSC26905TT... | Answered on Jul 16, 2017
The hose to the water dispenser up front cannot be connected and it is spilling the water onto the floor when the solenoid is activated.
LG LSC26905TT... | Answered on Jul 13, 2017
Check to see if the ice tray heater is working. It melts the ice a tad so the fingers can push the newly formed ice into the hopper.
LG LSC26905TT... | Answered on Apr 23, 2017
it sounds like the main control pcb is bad. it is not letting the defrost cycle work correctly and now the damper in the refridgerator side is stuck
LG LSC26905TT... | Answered on Oct 01, 2016
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
LG LSC26905TT... | Answered on Aug 11, 2016
Insulation does not melt - gaskets may be affected by hot temps.
Your condenser coils may be located on sides of fridge. If so the unit will be warm to the touch on the outside.
LG LSC26905TT... | Answered on Jul 29, 2016
get in a technician as there could be a loose electronic item( dry joint in the solder) or a crack across the printed circuit board
LG LSC26905TT... | Answered on May 07, 2016
I would use a multimeter to factories the wiring from the control board to the actual plug the extension cord for the fridge to check for electrical breaks after that your control board should at least power up
LG LSC26905TT... | Answered on May 05, 2016
LG LSC26905TT Side by Side Refrigerator Logo
571 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
lg refrigerator loses all power stops
  • Refrigerators
