Hello Roberto, to replace the laser pickup, you have to have knowledge of mechanics and electronics, and instrumental for the adjustments, any error can disable the functioning of your device
Hola Roberto, para reemplazar el pickup l?ser, tienes que contar con conocimientos de mec?nica y electr?nica, e instrumental para los ajustes, cualquier error puede inutilizar el funcionamiento de tu aparato
SOURCE: Pioneer PD4500 Single-Compact Disc Player 1.
Hi norberty
When you load a disk, do you hear a faint screaching sound, or the disc turn a tiny bit, but wont sart to spin? If that is what happens, then the spindle motor is lazy. You will need to replace it. Sometimes, you can get the motor to work again, by squirting some crc2-26 lubricant spray into the motor(through the bottom) Be careful not to use too much. Try this, if it doesnt sort it out, let me know here before you rate the solution, We can go further
regards
robotek
