It either the battery is dead or it has a technical fault see a technician to troubleshoot and see if it's the battery. It's also possible it's not charging at all because of the charging port is bad too.
How do I reset my Bluetooth speaker?
To remove all paired devices from the speaker, press and hold the Bluetoothbutton and the power button simultaneously for more than 3 seconds. This resets the speaker to factory settings and the speaker will be in pairing mode when you switch it on.Dec 6, 2018
SOURCE: coby mp-c7095
coby products are trash,buy yourself a ipod and return/trash your old coby player.ive had two coby products and they both stopped working for NO reason,one was 6 months old{portable dvd} another {mp3 player}was 3 weeks old!
i put 300 songs on mine now i have to start over and all the technician from coby said was"mail it in ,we'll send you a new one",what about the time and/or money wasted buying mp3s?
thanks for wasting my time coby!!!!
SOURCE: bluetooth wont charge or power on. when charging
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If
none of this is helpful then it may be that your battery is dead, if
that is the case then you will need to replace the whole headset. The
battery's are not replaceable.
Good luck from Headsets Direct!
