Radio Communications Logo
Lindsie Arthur Posted on Feb 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Galaxy 55hp CB. Why doesn't it turn on?
When I put it in the truck it was working perfectly fine. The other day I went to put it on and it had no power, nothing at all. What could it be?
Tom Chichester
Level 3:
Top Expert:
  • Radio Commun... Master 62,329 Answers
  • Posted on Feb 11, 2021
Tom Chichester
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672632
Points
975369
Possibly an open fuse
Jiff Lemmon
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 11, 2021
Jiff Lemmon
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2381
Points
7
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Dec 18, 2007
SOURCE: SCREEN AND POWER CUT
maybe the inverter board for the screen issue- the power issue seems to be LG has power board design flaw- basically last time I looked the power board is manufactured NOT by LG but by H&E ...who designs this stuff??
Anonymous
  • 6966 Answers
  • Posted on Feb 16, 2008
SOURCE: my galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Anonymous
  • 112 Answers
  • Posted on Jul 09, 2009
SOURCE: I have a Galaxy 959 cb radio. I have extended the
its normal its only cause your useung more power from the deck
Anonymous
  • 22 Answers
  • Posted on Sep 20, 2009
SOURCE: Was talking on cb and power supply went to beeping
THE BEEPS INDICATE THAT THE OVERVOLTAGE PROTECTION IS ACTIVATED,DO NOT HOOK UP ANY THING TO THAT POWER SUPPLY!!!OR THE FULL UNREGULATED VOLTAGE (20-30 VOLTS)WILL PASS FROM THE SHORTED REGULATOR TRANSISTORS TRHU YOUR GALAXY AND FRY IT.GET IT TESTED BY A PRO,USUALLY THE REPLACEMENT PARTS FOR POWER SUPPLY ARE DIRT CHEAP.
GOOD LUCK.
Anonymous
  • 631 Answers
  • Posted on Nov 25, 2009
SOURCE: loss of power on 1998 ford powerstroke 7.3
Generally the computer is reading a problem with the fuel pressure being to high or to low. The ICP is one problem it could be and you changed it. The other could be Fuel pressure regulator control solenoid or problems with the injector (s).
Testimonial: "thanks alot, this pretty much confirmed what i thought. someone befor me put an elec. fuel pump and straight wired it to the ign. thanks."
Galaxy 55HP. how do I install a Loudmouth kit?
it should have come with intructions . contact the one you got it from and see if they have them for your radio.
Set the carrier on the galaxy 55hp
you need a watt meter,a static proof screwdriver and a schematic. www.cbtricks.com has the service manual
Galaxy DX 55HP stopped transmitting, but will receive. When the mic is keyed the power meter goes past max and wont transmit. Tried different mics and no difference
connect to a meter. if there is rf power on a watt meter at full wattage. then the am regulator transistor is bad. less than $5 part.
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Galaxy dx 979
send it to me for repair. it has a bad soldr joint somewhere it is a common problem on all galaxy radios. 40.00 plus 10 return shipping. i have an internet cb shop so you can watch me fix it. email me at [email protected] if you want it fixed
Galaxy 2547 Base Radio
Its Possible it just needs to be re calibrated. Are you also using an external meter to check your output. If not get an inline meter to verify that in actuality your system is fine regardless what the internal meter is saying.......Hope this helps.......
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
