Try to lick the electrical parts and adjust the sound from low to high. Where you don't feel pain when licking is where the problem is.
Testimonial: "I would suggest you leave this site and spend your time on social media. Those have more interesting stuff for you. Don't waste your and other people times here!"
Time to read the manual. I believe the soundtrack on Super-8 sound film was optical. So there is likely a bulb that has burned out. Here is where you can get the manual and parts:
https://van-eck.net/itable.php?lang=en&size=0&cat=film&merk=28&type=ps-1000%20canosound
Testimonial: "Option Sound was not invented 50 years ago! The sound on Super8 mm films are magnetic and the projectors have a metal head to read the sound. same system as old stereo systems play voice cassettes."
Also optical has nothing with a bulb! it is fiber optic!!
Apologies: you're right about super-8, but optical sound on film has been around since the 1920's
Thank you for clarifying!
If it is optical you can tell by looking at the edge of the film which will have 1 or 2 lines that look like the groove on a record. Magnetic will look like a cassette tape with a brownish look. The optical one, uses a lens and a photodiode(s) to pickup the sound. If dirt gets into the pickup part, cleaning and blowing out with dusting spray will help. If magnetic perhaps qtip and alcohol clean any residue on the tape head will work. Also to make sure the film guides are not the reason, in that the film is not under tension or fallen out the guides or worn out. Using a small needle and working that around while the projector is running, you might get clicks or thumps in the sound to know that there is not an electronic problem.
Hi Ken,
Thanks a lot for the great advice.
The problem is that i am not able to locate the head. I was suspicious to an area that could be the head but even touching that spot or pushing the film into it to make a contact it wont generate any sound. I searched on the web for a manual, image or video for this model but had no luck. there is a company that sells the hard copy of the manual but it is not free and takes a while to be delivered. (I;ll go for this option as last resort).
I'll get back to you with some photos so we can have brain storming.
In the mean time if you found anything helpful please let me know.
Thanks again for your help!
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
SOURCE: Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
SOURCE: I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
SOURCE: my PS3 plays blue ray movies,dvds,ps2 and ps 1 and no ps3 games
hold the power button down when it is red till you hear the quick beeps then select the file restore this is a diagnostics menu..remember you have to hold the power button down till you see a menu that youve probably never seen
This is a common problem with these projectors. Usually happens after a film breaks or a bad splice goes through it. Pull the lens straight out and then remove the lens housing that holds the lens and the focus controller. The screws for the housing are behind the glued on cover that says frame and focus. Remove the 4 screws behind it, slowly lift the cover and watch for a loose leaf spring that sits behind the cover. It will fall out if the projector is standing up, so lay it on its back and it will just sit there so you know where to put it during assembly.
