SOURCE: MAIN ACCOUNT LOGIN DELETED. THERE IS ONLY A GUEST
the easiest way is to roboot the system in safe mode (press F8 or F12 for boot menu during the initial bios screen during startup).
access windows throught the admin account and make the changes permanent. Good Luck and pls rate this post.
SOURCE: I have trouble downloading on MacBook Pro.
this sounds like a temp folder has your downloads and some software that is set to open at start up is keeping your files.
i suggest making a account or looking thorough your previous downloaded files
SOURCE: I cant create another user account on my windows 7
Click Start then in the search box type: System Restore
When the results of the search is returned at the top, select System Restore. When System Restore opens, select a Restore Point (date and time) before you deleted the Guest Account. System Restore will not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the date and time you selected).
You don't have to use the latest default date that it will bring up first. There is an option to see more dates or restore points.
