Toshiba TV, Model - 49L621U
SOURCE: Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: [email protected]. (866) 839-5888
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
I have a Toshiba, model #49L621U. While watching movie using firestick, screen went black but had sound. Turned it off, back on, unplugged everything to reset. Tried it all. When I turn on TV I have a black screen, no sound but when I turn off TV words Toshiba come up but screen goes black.
Did you ever find a solution? I am currently having this exact issue
I have the exact same issue as listed above. The screen is black but when the TV turns off the Toshiba logo comes on the screen for a quick moment. Have you found a solution to the problem?
