20 Most Recent Toshiba 62HM95 62" DLP HDTV Questions & Answers
I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62h
There is no bulb to replace on a rear projection set. It uses 3 separate picture tunes 1 red 1 Blu and 1 green coupled to magnification lenses that focus onto the mirror which the directs the image thru the screen. Access is usually by removing the trim ring and screen from the front. Access from the back only gains access to the circuit boards. Be very careful as each tube has its own high voltage transformer which can have from 50000 to 150000 volts.
10/7/2016 11:08:25 PM • Toshiba 62HM95... • Answered on Oct 07, 2016
Toshiba 62hm95 makes whirring noise and color is distorted
Your color wheel is going out and needs to be replaced. Toshiba does not list a part# for the color wheel. They expect you to have the whole light engine rebuilt. You should be able to find one on ebay. Or other sites like that. Good luck to you.
6/6/2016 12:26:14 PM • Toshiba 62HM95... • Answered on Jun 06, 2016
0answers
Why won't screen come on
Is it a buzzing sound? Check the lamp, the glass of the lamp may be shattered? www.aaatvservice.com
8/16/2014 5:57:20 AM • Toshiba 62HM95... • Answered on Aug 16, 2014
Where are toshiba dlp 62hm95 fuses
I looked at the power board online and I do not see any glass fuses. I only saw the pico fuses which you unsolder and resolder. Here's an image of the power board: http://tvpartsandmore.com/wp-content/uploads/imported/46HM95-TOSHIBA-23764257-POWER-SUPPLY-UNIT-46HM95-52HM95-62HM15A-62HM95-62HMX95-191208846050.jpg What is the problem with this TV? www.aaatvservice.com
8/16/2014 12:59:41 AM • Toshiba 62HM95... • Answered on Aug 16, 2014
Toshiba 62 H and 95 TV will not start Green blink turn to read to bring
Likely a bad lamp. if not, perhaps a bad color wheel.
5/8/2014 3:00:31 AM • Toshiba 62HM95... • Answered on May 08, 2014
0answers
0answers
2answers
Chip going bad
If they are white dots that is the OPTICAL LIGHT ENGINE, check all inputs to see if issue the same and you can POST a photo here which might help.
10/21/2013 8:31:18 AM • Toshiba 62HM95... • Answered on Oct 21, 2013
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
10/13/2013 9:28:44 PM • Toshiba 62HM95... • Answered on Oct 13, 2013
Toshiba 62HM95 62" DLP HDTV Logo
119 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
tv only show black white lines shows no
  • Televison & Video
