20 Most Recent
Samsung PN50B550 50 in. Plasma HDTV Questions & Answers
Hi I have a samsung
Your Samsung PN50B550 does have a USB port for USB devices formatted to FAT16 or FAT32. It supports playback of MP3 and JPG, but not movie formats through the USB drive, at this time.
I hope that helps.
________________________________________
Samsung PN50B550 Manual
Download
Turn on my 50" samsung plasma i have sound but no
Hello, this usually means that a cable or something is not plugged in properly.
Maybe you just put in the audio cable and no cable which can transmit video?
If it's a HDMI cable make sure it's plugged in properly and that you're on the right channel.
Anyone know why the Samsung PN50B550 50in Plasma
I had this issue..Go to Menu and go to the burn in troubleshooting and run the scrolling feature..Scrolls whites and darks..Run for an hour..I had it on both sides..From watching 4 X 3 pic, image retention..Should clean up fine
I have a Samsung PN50B550-T2F (almost 2 years old)
No,this problems 100% a circuit board it is the cause and the problems.It is dying and shorting out not axact sure which buffer boards are causing this the upper or lower buffer boards are causing this axactly,but have narow it down it is those 2 buffers boards are shorting out,shops around for local repair shops,cost are different from shop to shops,should cost u around 300-350 for parts and labors.
I have a
Did you find a solution to this? I have had the 550 for a month now and am experiencing the same problem.
