Can I set one time on 1st alarm and 15 minutes later on 2nd alarm for radio only or is one alarm for weekdays and the other for weekends only? What i want to do is set one time on one alarm and 15 minutes later on 2nd alarm so that if I decide before first alarm goes off that I want more sleep, I can turn off first alarm.
SOURCE: Motorola E815 alarm quit working
I've had a similar problem with alarms not going off. In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off. Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes. The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
SOURCE: ow do i set the time of my sony alarm clock with radio?
I just did the trial and error thing. it's okay now. thanks
SOURCE: setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy
"www.armitron.com/watch_instructions.asp" into your search engine and
you will see a list of illustrations of watches and associated
instructions.
Choose
the one that looks like yours and download the PDF file.
SOURCE: Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
