20 Most Recent
Sangean RCR-22 Clock Radio Questions & Answers
I got a new Sangean
I just had the same problem which you find posted here on FixYa.com. The problem solved itself overnight for me. I left the RCR-22 unit plugged in and searching for the signal when I woke up the next morning the time was set and the Atomic signal indicator was solid instead of flashing. It has kept perfect time since then. My only issue is that setting the alarm clock-radio is complicated.Robert Hovestadt
Sangean radio
DT-210
Hi Fernando, you put the brand and model of your radio, but do not indicate what problems you have
Comment what you need, so I can give you some idea
I wait your answer
Greetings Franco Dosil
Hola Fernando, pones la marca y el modelo de tu radio, pero no indicas que problemas tiene
Comenta que necesitas, asi podre darte alguna idea
Espero tu respuesta
Saludos Franco Dosil
