20 Most Recent
Sangean ATS 505 AM/FM/SW Radio Questions & Answers
I HAVE A PR-D3L, CAN
- If you have any comments you can feel free to leave them here.\
- Hope this helps and thank you for using FixYa.
Regards,
Tony
I want to buy a
It just need 5 watts of power. So with 6 volt DC input, you will need at least = 5/6 amp ( says 1 A).
However You can use a bit higher amperage of your power adaptor to get better performance.
Regards
Wont work
Did you mean that it not working at all or the powering unit is not distributing the power from it unit?
Please repla me back with comment
thanks
Sangean PR-D3L - How do I change between 12 and 24
Archer, I have read the entire PR-3DL manual and there appears no mention of a 12/24 hr setting, unlike certain other Sangean radios. The instructions for setting the alarm do not mention 'a.m.' or 'p.m.' .
Apparently, the clock is a 24:XX:XX display only.
SANGEAN ATS505
try the power switch a few times and more force than usual.
ATS 505 Power Supply Problem
Make sure no other buttons are held down when powering up, although you usually see a clock on the display if there is power but the unit is locked up for another reason.
The fact that you've tried batteries and you've tried the PSU suggests to me that there is some other problem with the radio, it could be as simple as a dry joint, but without experiencing the same problem myself it's not possible to suggest anything further.
