SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
SOURCE: Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
SOURCE: lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Re: IPhone doesn't connect with wifi automatically - password not recoginized HELP!!!
Yep, I had the same problem with my iPhone as well (32GB 3GS).
Had the signal NO problem for about a week then POOF it was gone. WTF?
Prowled the boards looking for a solution.
Tried resetting the phone, resetting the Wi-Fi, switching airplane mode on and off, forgetting the network, etc.
HERE'S YOUR SOLUTION :
Go unplug your wireless router's power cord.
Wait 30 seconds.
Plug it back in.
Your iPhone will reconnect, and you'll be back in business.
Jack
SOURCE: my new LG P970 won't
Go to settings, wireless networks, access points and then hit menu button then add access point and enter same address as the one that you are currently connected to then select the access point you just made and problem should be solved, reason why is there was a default proxy, this should fix your problem
