20 Most Recent U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Questions & Answers
3answers
How to be happy everday
Hi There,
There is no universal formula for happiness. The cause for happiness is different for different people. It is as diverse as people and their priorities.
I can tell you what makes me happy everyday.
It's my dogs Ursa and Poppy greeting me at the door when I get home. They get so excited and happy to see me that anything that may have been bothering me is forgotten.
I hope you find find yours...
Best regards
Mike
1/10/2019 8:28:22 AM • U.S. Robotics... • Answered on Jan 10, 2019
0answers
0answers
How do I determine what firmware version my MAXg
The latest firmware release for that router is found HERE.Be very careful to follow the instructions; especially I suggest connecting direct cable to your router to insure there are no interruptions in transmission. Since I don't have a USR I can't tell you where the current firmware number is located. However, the usual places are directly on the router itself, perhaps on the bottom or rear. Also check the manual, although usually manufacturers don't use this because many times they supply manuals for several models and don't want dated material. It wouldn't hurt to send an e-mail to USR support, most of these companies are pretty good about responding. My suggestion is to flash your firmware only if you have a problem and no other choice.If your flash goes bad or is interrupted your router will be bricked.
10/2/2013 10:04:32 PM • U.S. Robotics... • Answered on Oct 02, 2013
Owners manual
I cut the text from your problem: U.S. Robotics MAXg USR5461 and pasted it in to Google. The first non-sponsored result was:http://www.usr.com/support/product-template.asp?prod=5461
9/17/2012 11:34:53 AM • U.S. Robotics... • Answered on Sep 17, 2012
The wireless light is on,
Assign a fix IP address to your iPHONE (out of range of DHCP) and reboot your URS5461.
9/20/2011 7:44:01 PM • U.S. Robotics... • Answered on Sep 20, 2011
0answers
I can't enable the UPnP
Dont need it. Its a security risk anyway. Try and do without it.
7/18/2011 4:20:24 AM • U.S. Robotics... • Answered on Jul 18, 2011
2answers
How do i change my
You can change password with below method.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
5/15/2011 5:03:56 PM • U.S. Robotics... • Answered on May 15, 2011
3answers
My printer (HP LJ 1200),
Try to get to the Hp ..and download and install the driver for the printer into the windows 7 ...cause this may be the cause for what it isnt seen by the pc ..specially if they are in network ...the others seen it cause they have the xp driver ..but for this one you have to load the w 7 driver..
Also try to make the settings again if this is the only pc connected to the router ..
or ..if the driver is installed ..get to start ..printer and faxes..and run the add new printer wizard ..and look for the printer by name in the network ..(after you install the driver..
3/22/2011 6:27:33 PM • U.S. Robotics... • Answered on Mar 22, 2011
CANNOT RECALL NETWORK KEY
http://download.cnet.com/WirelessKeyView/3000-2092_4-10614187.html Download and run, and enjoy your internet! Just make sure you're in range of the router in question. Leave feedback!
2/4/2011 6:06:35 PM • U.S. Robotics... • Answered on Feb 04, 2011
My default IP ADRESS is192.168.1.1, and am trying
If you ever lose your settings or if your settings are changed and the router is not functioning properly, you can come to this area to restore your saved settings from the backup file you created. Click Browse to locate the backup settings file you previously created. When you have located it, click Restore and the settings saved within this file will be applied to the router. If you did not create a backup file, you may need to restore the factory default settings.
device3.gif Factory Settings If you ever want to erase all personal settings of your router, come to this area and click Reload to restore the factory default settings. All the current settings will be lost. If you change the router's configuration and it stops functioning properly you can reload the factory settings to fix it.
device3.gif The other method to restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds. You will lose all of your personal settings if you restore the factory default settings. You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
11/8/2010 1:05:40 AM • U.S. Robotics... • Answered on Nov 08, 2010
I have us robotics USR8054.
10/17/2010 4:09:08 AM • U.S. Robotics... • Answered on Oct 17, 2010
I bought this US Robotics
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
10/4/2010 8:55:46 PM • U.S. Robotics... • Answered on Oct 04, 2010
2answers
I reset my usr5465 using
Typically, a good router will allow you to configure it only bvia a wired connection, to prevent unauthorized remote users trying to hack it.
Please try using a network cable (patch cord) to connect to the router's LAN socket directly and attempt reconfiguration then.
9/16/2010 2:35:05 AM • U.S. Robotics... • Answered on Sep 16, 2010
Wont work
What do you mean by it won't work? What issue are you having and how long have you owned this unit? How long have you had this problem? Once I have more information I can assist you further.
Thank you,
Lee
7/19/2010 6:45:56 PM • U.S. Robotics... • Answered on Jul 19, 2010
Ps3 game system is able to connect to the internet
1. this could be the network itself
Bandwidth overload or out of balance.
This is a server issue sometime with gaming servers.
2. It could be your system is too close to a cell phone or cordless phone or digital TV. Try moving the unit about 20 ft away and see it you get better signal strength.
7/5/2010 1:09:49 AM • U.S. Robotics... • Answered on Jul 05, 2010
How do i change my password.us robotics wireless
ACCESS THE DEVICE SETTING THRU IP ADDRESS ON BOTTOM OF DEVICE IS USUALLY AN IP TYPE IN EXPLORER ADDRESS SPACE THE IP ADDRESS .. EXAMPLE \\199.210.01 .01
OK THERE WILL BE THE NOMENCLATURE PAGE WITH OPTIONS TO CHANGE PASSWORD
6/15/2010 8:45:28 PM • U.S. Robotics... • Answered on Jun 15, 2010
When trying to connect my iphone 3g to the
I wonder if your router is set to perform MAC address filtering. If so, you have to either find the MAC address of the iPhone's wireless card and add it to your router's appropriate list, or set your router to not filter by MAC addresses.
Just my 2 cents... Carlos
5/13/2010 1:35:34 AM • U.S. Robotics... • Answered on May 13, 2010
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
60 questions posted
Top U.S. Robotics Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • U.S. Robotics Computers & Internet
Most Popular Question
printer hp lj 1200
  • Computers & Internet
