This should enable you to restore the system partition of a VAIO to factory state. It is applicable to VAIO computers preinstalled with Windows Vista, unless the recovery partition has been removed.
Note: Additional information on the recovery system can be found in the Troubleshooting and Recovery Guide delivered with your VAIO computer. This guide is also available on this website for each model.
Important Notice:
All data on the C: drive will be deleted in this process. Please follow this solution only if your personal data is backed up or redundant.Proceed as follows to recover your VAIO computer to factory state:You can access VAIO Recovery Center in two ways:Within Windows:Close all open programs. Click the Start button and then click All Programs. In the All Programs menu, click VAIO Recovery Center.If Windows does not start:Start or Restart your VAIO.Press the F10 key several times while the VAIO logo is displayed.
Press the Enter key when the Edit Boot Options screen appears.
Wait until the VAIO Recovery Centre is loaded.Choose Restore C: Drive and click Start.
VAIO Recovery Center will offer options such as using VAIO Hardware Diagnostics for your consideration. If you want to proceed to the recovery process, please click Next.Tick the checkbox next to "I Understand".
Click Start and confirm with Yes when prompted.
The recovery process will continue automatically up to the Welcome to Windows screen. Depending on the model, this process may take extended time to complete, but requires no user interaction until completion.
It should be fixable. You should try running the factory restore again.
SOURCE: Sony vaio Adopter is beeps when i connect to power supply
I think ur adapter have some problem.Better to change ur laptop adapter and check it.whether it give same problem.Then please contact nearest service center.
Thanks
SOURCE: i just reset my sony vaio to factory settings and
try downloading the audio driver and install it. if you are using Sony VAIO PCV-J200 you can download your audio driver here http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVJ200&upd_id=174&os_id=7
SOURCE: want to reset Sony VGN-NR160E/s Vaio NB to factory
Just power on your laptop and keep pressing F10 key. You will get one wizard to restore your laptop to factory settings.
iTechGuru
www.itechguru.in
try the recovery disk or the recovery option of the sony vaio
SOURCE: sony vaio vgn-sz330-p factory restore
i have sony vaio (model vgn-sz680). i need help to reboot my laptop to factory setttings. i dont have restore cd.
which operating system ?
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased.
Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
hope this helps
2-Click the "Help and Support."
3-Select the "Vaio Recovery Wizard" option.
