IT IS AN MSI L1300 WITH AN INTEL ATOMN450
SOURCE: brought a msi L1300 from
This link has the information that you need to reset your system...Download the Manual and drivers.
if you didn't receive the system disk when you purchased the laptop, see if you are still able to create a set...this info is covered in the manual
http://www.msimobile.com/level3_productpage.aspx?id=203
SOURCE: MSI P67aC43 B3 Lga1155 Intel
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
