SOURCE: Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
SOURCE: I have a Kenmore Upright Freezer. I need to
I unplug mine and let it take several days. You break a line or punch a hole in a line and the freezer will be ruined. Just let it thaw out on its own to prevent damage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: my kenmore 9 upright freezer feels warm on the
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
