SOURCE: the ladies disney citzen eco-drive requires a charge
It needs LIGHT ... Put it under a bright lamp or out in the sunlight. It is SOLAR powered/charged. You may use a fluorescent lamp or an incandescent lamp but it will take longer to charge to full. If you use a regular light bulb (incandescent) make sure to keep 20cm distance from the watch to prevent overheating.
When it gets low on charge it will switch to only moving the sweep or second hand every 2 seconds, then after a while it will stop all movements and may move the hands to 12:00 (power saving mode). Again, It will need to be put in bright light to recharge.
