How to Fix a KitchenAid Stand Mixer That Is Leaking Oil
https://www.youtube.com/watch?v=8eKHVvNX5eY
SOURCE: Which way do the brushes go on the K45SS stand KA Mixer?
Look carefully at the bruch, it should have a cupped chape that matched the curve of the armature. If it went in wrong, you may have wither broken the brush, or messed the armature. You can get new brushes online from many parts retailers, just google you part number and the word "brushes"
SOURCE: Trying to fix my KA mixer, and cannot get the planetary housing o
A screwdriver is for turning screws. What you need is a drift pin slightly smaller than the diameter if the pin you are trying to remove. If you can back the shaft up with something heavy like a hammer head and then try to drive the pin out you will be successful. They are pressed in with a light press fit and should yield to the above technique.
