SOURCE: Power consumption excessively high
Yes a higher SEER can help reduce electric costs. However. In most cases this will require changing both the indoor and outdoor units. In other words if you have a 10 SEER matched system and only upgrade the outdoor unit to a 14 SEER you will not get exactly 14 SEER efficiency. They must match.
Before excepting bids on new equipment I would first higher a licensed company to measure the Heat gain/loss from you house. This information will tell you if the current system was originally sized correctly. The improper sizing can lead to high electric bills as well. I hope this helps.
SOURCE: Bizhub C351 Magenta Image Unit Problem
Sir,
The print head assembly has failed. Replace the print head assembly
SOURCE: Aopying/printing gets lighter as you keep printing
i think you need to change the developing cylinder
http://betulinmesinfotocopy.blogspot.com/
SOURCE: Is high CPU usage will make battery life reduction?
Anything that requires more activity from your CPU will shorten the battery charge. It is eating power. I am not sure about "Magician".
SOURCE: high fuel consumption
If MPG suddenly drop, it could be for several reasons, but usually your engine needs a tune up to restore MPG. If engine is running fine, no misses, etc., then look for air filter to be changed, this will effect MPG the most if dirty and restricting airflow which will then increase fuel flow. FREE-PPV.com
