20 Most Recent
Minolta Di3510 All-In-One Laser Printer Questions & Answers
Tengo una fotocopiadora minolta di
Have you had the developer and drum replaced or does the screen say Replace PC Drum? Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
TRY this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Como reparar error cof32
Has the developer been replaced and the F8 function run and has the counter for the developer been reset. Also the drum should be replaced. at the same time. If this was already done did the person doing it use a vacuum cleaner to remove the old developer if so the Sensor for this code was destroyed by the static electricity from the vacuum cleaner never ever use a vacuum cleaner to remove old developer Btw, I’m available to help over the phone in case u need at
A MALFUNCTION WAS DETECTED - CODE C0500
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Errorcode cof32
Imaging Unit calibration failure. This code means the machine is seeing a toner concentration in the Imaging Unit that is either to high or too low. This problem can only be resolved by a service technician. Salvaging the existing developer mixture is often not possible. The Imaging Unit will need the the developer replaced and calibrated via the service mode.
Good Luck and Thank You for using Fixya.
Hi i have minolta Dialta 520 Photostate machine
The error code C-1028 on a Minolta Dialta 520 photostat machine typically indicates a problem with the paper feed system.
Based on your description, it seems that you have already replaced the PWB-B Board and checked all jacks, but the problem persists. In this case, there could be a few other potential causes of the error.
- Paper feed motor
- Main control board
- Gears or other parts in the paper feed system
- Paper feed sensor
Regarding the Bet Pin, it could be the name of a specific pin on the PWB-B board or in the paper feed system, but without more information about the specific location or context it is hard to say exactly what it is referring to.
It is recommended to consult the service manual of the machine, or contact the manufacturer or a professional technician for further assistance. They will be able to diagnose the issue and provide the necessary steps to fix it.
