Possible reason on web page:
http://www.officeimagingsystems.com/id173.html
Quoting from link:
L1vSub code 00: Scan forward problem, motor, sensor, board
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
SOURCE: code L1 on a sharp AR-153E digital copier. Any
L1 code means problem with scanner unit. cheque to see if scanner is locked if not , lube rails and ck scanner motor.
