Printer prints 1-3 copy straight,but ROUND 3-10 is off centered
SOURCE: Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
SOURCE: Printing not centered
If the other 7 printers print the barcode from the same software in the right place then the problem is with your printer.
Try to recallibrate the printer by doing this.
TURN OFF
HOLD THE GREEN BUTTON ON THE FRONT OF THE PRINTER DOWN AND TURN ON THE PRINTER
HOLD THE BUTTON UNTIL THE LIGHT FLASHES 2-3 TIMES RED AND THEN LET THE BUTTON GO
the printer should now perform a recalibration.
If this dows not fix it, then either the printer has a permanent fault or the printer driver/software is not set to the correct label width.
SOURCE: My ricoh printer is not printing straight!
if those tips don't work email me at [email protected]. We just had that problem resolved... beleive it or not it was really simple.
SOURCE: when copying or printing, there is a whitish strip
Remove the toner cartridge and while keeping relatively level, shake it from side to side. Re-install and try a test print. If the light band has gone away then problem solved. It does mean that your toner crtridge is probably starting to get low on toner. 90% of the time, print quality issues on HP lasers are toner cartridge related.
Good Luck and Thank You for using Fixya.
