20 Most Recent Canon imageRUNNER 2200 Questions & Answers
A E-846 is a problem with the scanning lamp calibration. To resolve the problem you can do one of two things. First you will have to replace the scanning lamp & the scaner inverter PCB as a pair with the up-dated version PCB. Or if you have a parts machine, you can use a working scanning lamp with the PCB and replace them as a set or pair. You can not use a lamp from one copier and a pcb from another.. They have to be a matched set... Good Luck
Canon... | Answered on Jul 04, 2019
i am Copy error cde E000202-0001 Pls Help Me
Canon... | Answered on May 14, 2019
Did you press additional funcation? You have to in order to get in to service mode. Then go to copier, then funcation, then CLR/ Clear, then ERR, the hit the OK on the display, then turn the main power switch OFF then back ON. It should reset the code, if not you have a problem with the fixing unit.
Canon... | Answered on Apr 09, 2019
It's probably a sheet of paper between the main body and finisher
Canon... | Answered on Apr 05, 2019
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Canon... | Answered on Feb 02, 2019
Hello romdos. This forum"FIXYA" takes a dim view of peple like me who try to help people. Unless the help I provide is ironclad perfect advice. But they can kick my "rating' of expertise down a notch or two. I prefer helping folks if I can. :-) I see two potential problems with your scenario. First, Adobe Reader 8 is so far been notoriously problematic as they basically pushed out this new version with a smile on their face saying "they will find a way it work" referring basically to the rest of the world's app and software providers. Second, and you may be ahead of me on this, The Canon 2200 is .....well..... right their on the cusp of being called old.3 years is almost an eternity when it comes t technology.But Canon it great about maintaining support as far as updating their print drivers The possible sticking point is the part that requires a technician to come in and hook his laptop up and updating the FIRMWARE on the device itself. This, as you may know,is the instruction set the copier uses to interpret the commands and data it recieves,and to accurately respond to those commands. As new applications arise and commands and requests are made that no software engineer could have possibly anticipated when the copier was introduced to market , a service tech must go in and "flash" (reprogram) the copier so it knows how to handle/respond data and commands that could never have been anticipated. So we have new versions of programs, new potential capabilities,new drivers that should be loaded by the end user, and the distinct possibility that a technician may need to install a new operational program that gives the copier definitions and answers to questions that did not exist mere months ago. The answer to your question, Im afraid is not simple. If you choose to critique my answer to you question I encourage you to be honest,but leave mu nuts in tact .I have told you the truth,but I could not "fixya". But I bet I explaimed the big picture better than alot of these knottheads who cherry pick customer's question to make sure they get a good grade. I just hope I heped ya. Take care..........SPINAL.........
Canon... | Answered on Dec 01, 2018
check the hard disk and the ram.it will be ram 80%
Canon... | Answered on Aug 30, 2018
there is a problem on software.if you know how to update the firmware, thats the solution
Canon... | Answered on Jan 30, 2018
this is pertaining to ckt board controller problem, and we need to coordinate this with canon service for the replacement.
Canon... | Answered on Jun 14, 2016
there is no corona wire but a primary charging roller pls clean it if both ends of the roller looks rough or cracky try replacing it and clean transfer roller as well.
Canon... | Answered on Apr 28, 2016
E000261-0000
Canon... | Answered on Feb 19, 2016
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If nothing of these helps, send more specific description of problem.
Hope it helps
Canon... | Answered on Sep 09, 2015
hi the solution is : E000 0000 : Description: Startup error
The temperature detected by the mainor sub thermistor does not rise to the specified value during startup control.
Solution:
- Check the fixing film connector.
- Replace the fixing film unit.
- Replace the DC controller PCB.
Canon... | Answered on Aug 13, 2015
It has to do with your network. Call your IT person to repair it.
Canon... | Answered on Jul 23, 2015
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Canon... | Answered on May 15, 2015
what you can do is,press * 2 8 *,copier,function,clear,error and ok
Canon... | Answered on Apr 03, 2015
These copiers are notorious for having slipping one way clutches in the feed rollers or your feed rollers are worn out. get a copier tech to fix it. there is no simple quick fix.
Canon... | Answered on Jul 31, 2014
Canon imageRUNNER 2200 Logo
446 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
fix error code e000202 0001
  • Office Equipment & Supplies
