Televison & Video Logo
G
Gloria Kroll Posted on Jun 23, 2018
My Mitsubishi Tv Model #WD60C10 will not power on. I moved it near a cable connection after hooking it up wrong to my tv. Didn't drop or bump it, good outlet checked, no power now. It powered on be
5 Related Answers
zowl
Gerald Ridge
  • 15 Answers
  • Posted on Aug 17, 2007
SOURCE: no power
During moving the power connector which looks like a big telephone plug or a data plug may have been wrenched loose, from the internal connector, inside the plastic plug. Use the power plug from the other phone to test. There is no battery in the phone to charge. If changing the power adapter and plug fixes the problem have you telephone company check the connector or go to radio shack and buy a plug and a cheap tool to replace the plug.
Anonymous
  • 6966 Answers
  • Posted on Oct 23, 2007
SOURCE: CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on Jan 18, 2009
SOURCE: moving tv to another cable outlet
I f you have cable at the new location follow it back to a splitter. Remove the one you used to use and screw in the one you want to use. They should all terminate at the same location.
Anonymous
  • 25 Answers
  • Posted on Feb 08, 2009
SOURCE: Mitsubishi ws-65313 No Picture
YOU HAVE AT LEAST A DOZEN VIDEO INPUTS ,THE BEST IS THE MONOLINK.WHATEVER WAY YOU HAVE IT HOOKED UP .YOU HAVE TO GO TO THE INPUT MANUAL AND PICK OUT THE ONE YOUR ON .IF YOU DONT WANT TO SPENT 30 BUCKS ON A THE DVI-HMDI MONOLINK CABLE.OR 10.00 ON THE R/G/B TRI CABLE ,FIND ANY COLOR CRAPPY LITTLE SKINNY **** SPEAKER JACK CXABLE AND STICKIT IN THE YELLOW INPUT 1,2 0R 3 THEN GO ON THE INPUT SCREEN AND SCROLL DOWN TO WHATEVER INPUT YOU PUT IT ON.AND OF COURSE HOOK IT TO THE VIDEO OUTPUT ON YOUR BOX SIT BACK AND ENJOY THE 480 P RESOLUTION YOU WIL GET WITH A 50 CENT WIRE.
Anonymous
  • 828 Answers
  • Posted on Jul 20, 2009
SOURCE: Drops connection after a few hours
ask your internet provider why your internet connection drop, your Router is working properly.
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
How do you hook hmdi cable up to Mitsubishi hdtv wd62528?
Must select correct input, on your model the input used is not "labeled" HDMI, look in your user manual.
I am trying to connect my hp laptop to my '73mitsubushi tv with an HDMI cable. TV says wrong format. Help!
you have to select the monitor out on the computer is ether the f1 or f2 key on the laptop
2answers
Somebody hung my TV for me but, didn't put the power cord in so, I'm trying to navigate blindly, it's hung on the wall, to attempt to plug in my power cord but can't find it. Can you give...
Tries look near the square arm plate that have four screws holding the tv look for a hole with 3 steel prongs that ur tv a/c hole for power cord hook up.But if the tv it is very closed and hook up tight and flust to the wall will not able to hook up a/c power cord must take off wall to be able to hook up a/c power cord.
My TV is connected to cable. I want to connect a VCR to the TV....how?
You didn't give model numbers.... But for most equipment: hook the VCR to the TV's Yellow, White, and Red jacks using a composite video cord. Or if both have screw on Co-Axial type cords:
cable in to VCR's ANT IN, TV OUT to TV's IN.
1helpful
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Mitsubishi vs-45609
You should have two antenna inputs A & B. Most commonly the RF or TV output on the back of the cable box is connected to antenna A and the TV has to be set for channel 3 or 4 depending on which station is not available in your area. If you don't get a picture on 3 or 4 then switch the cable box to antenna B or find the switch on the remote that allows you to remotly switch antenna inputs. If your TV has a connection that says "cable out" don't use that one as that is for a more complex setup. I hope this helps you.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
