20 Most Recent Mitsubishi VS-45609 TV Questions & Answers
0answers
0answers
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs you will need to use a digital seck top box and use that units remote to tune the TV if there are any (needs a user manaual) use the buttons on the TV lower casing to tune up none of the all in ones remote buttons work for all TVs functions you are lucky if it turns on and off and changes channel index-bwbjq1d2inqbxh534mfqkm1n-3-0_0.jpg
4/29/2017 9:54:01 AM • Mitsubishi... • Answered on Apr 29, 2017
I have a videocon 7641G
Contact me on this no 9268048431 then I will solve your problem.
5/13/2016 6:36:20 PM • Mitsubishi... • Answered on May 13, 2016
I dont have the original remote to hold down 9&QV button what now?
You should have its original remote to get these buttons to hold on. Only original remote will have these buttons. No universal one have. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier. http://electrohelponline.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Check this link too. http://remotesearch.blogspot.com/
5/8/2014 6:31:05 PM • Mitsubishi... • Answered on May 08, 2014
I do not have original remote to push 9&QV button to unlock mitsubishi what can I do?
5/6/2014 2:59:11 AM • Mitsubishi... • Answered on May 06, 2014
Mitsubishi entire remote/tv locked
You can try pressing menu 2470 on the remote this will bring up a menu that says intialize. High light intialize and press enter. your tv will cut off, reboot and work as it did from the factory. Any personal prefrences that you had, color, input names, auto program,and locks should be reset. Hope this helps
5/5/2014 8:20:16 PM • Mitsubishi... • Answered on May 05, 2014
Picture is fine but no volume on my mitsubishi vs 45609
Make sure you haven't bumped the MUTE or SAP/LANG buttons on your remote.
4/28/2014 8:47:06 PM • Mitsubishi... • Answered on Apr 28, 2014
Leakage coolant
Contact any service technician. The set has to be disassembled to repair this fault. It is a skilled work. Gopakumar Gopalan Google
4/27/2014 5:47:44 PM • Mitsubishi... • Answered on Apr 27, 2014
NO POWER
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
4/15/2014 7:10:36 AM • Mitsubishi... • Answered on Apr 15, 2014
Pic is fine but no volume!
the televisions seakers could have overheated and shorted, your best bet would be to call your local television repair and have them come take a look, from what ive seen in the past the older style projection tv's like your own arevery hard to find parts for and in most cases it's cheaper or smarter to just replace the telelvision with something new.
4/8/2014 6:17:55 PM • Mitsubishi... • Answered on Apr 08, 2014
How to replace cicuit breaker mitsubishi ws 48511
It does not have a circuit breaker but if green light comes on for a few seconds and goes off: Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC: UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF. PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together. Watch for power light to blink in a sequence: 1 blink-then 2 blinks-------no error 2 blink-then 1 blink-------X-ray protection 2 blink-then 2 blink-------SHORT PROTECTION******* 2 blink-then 3 blink---------deflection circuit problem 2 blink-then 4 blink---------vertical circuit problem ******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down. SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN. IF IT IS 2 AND THEN 2---USUALLY CONVERGENCE CIRCUIT PROBLEM let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
2/12/2013 1:08:14 AM • Mitsubishi... • Answered on Feb 12, 2013
Samsung pcl5415r convergance
Download the service manual to this set by internet. It will have all details about this adjustment.
11/23/2012 1:06:09 PM • Mitsubishi... • Answered on Nov 23, 2012
Colors do not line up to each other
I would replace your convergence chips and see if it fixes the problems. I know some tv's also have a menu for fixing the convergence. Try that first.
10/30/2012 7:44:04 AM • Mitsubishi... • Answered on Oct 30, 2012
Mitsubishi tv model vs-45609 error code 1-2 what can i do
it was a self diagnostic, that was mean no error detected. just turn off and turn on the tv.
10/28/2012 7:15:21 AM • Mitsubishi... • Answered on Oct 28, 2012
I locked the front control buttons by accident i do i unlock i lost the original remote
Buy it original remote control. Without it, you can't unlock it.
10/20/2012 4:53:49 PM • Mitsubishi... • Answered on Oct 20, 2012
Mats electronics
It is around $9.
9/29/2012 4:59:51 PM • Mitsubishi... • Answered on Sep 29, 2012
I can turn my tv on and the green light comes on i can hear the set turning on.. but after 10 seconds the whole tv shuts off without anythig showing up on screen.. is this worth fixing?
the tv is getting turn on but detect an error that is why go to safety mode.if you know how to check component parts tried to disconnect first the ballast board which may have shorted component. then turn on the tv set if the tv doesn't shut off that was mean the ballast board is the cause of shut down.if you think you can not do the repair just send it to the service shop to do the job.
9/6/2012 12:13:20 PM • Mitsubishi... • Answered on Sep 06, 2012
My 2001 mitsubishi Model VS-45609 gives me the error code 2,3.. can anybody help me from here?
could be the convergence ics or the yolks.http://www.shopjimmy.com/
9/6/2012 3:09:19 AM • Mitsubishi... • Answered on Sep 06, 2012
Mitsubishi VS-45609 TV Logo
124 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
dont original remote hold down 9 amp qv
  • Televison & Video
