20 Most Recent
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Questions & Answers
I have a mitsubishi ws-65315.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Connect Apple TV
Your TV MUST support 720P or higher resolution to work with an Apple TV.
Hdtv or converter box
If the TV is already hdtv...no. Try reprogramming tv to find hd stations or if receiving signal from outdoor aerial make sure aerial is digital and facing right direction.
Vertical Alignment
I would take a good look to make sure it got back together correctly, set does have a hidden adjustment menu once entered the Mitsubishi remote can adjust a lot of things including centering etc, want to be careful in that menu,,,confirm the model and I will give you the four digit enter code for the set.
I have a mitsubishi 1080 series wt-42311
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
