Televison & Video Logo
steven teel Posted on Jun 17, 2018
Does anyone know what the most common problem with a tv? that will turn on stand by light comes on but no picture or sound. It's a proscan 50in Led
3answers
My Proscan 50 LED TV PLDED5066A-E picture totally went out, but the sound is normal for each station. Do I need a new power supply?
In most of the case, the problem is defective LED back lights strips.
You may try a new power supply first.
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Hisense 50in hd tv has no picture but has sound
Sounds like either the CCFL tube (like a mini florescent tube) or the inverter that powers it has blown.
Proscan 42" LED 120hz TV no audio out except with hdmi
Look for the setup menu on the TV. It is common that you need to select either TV speakers or external speakers as only one will work at a time. If you want the sound to come out the audio output, you may need to select this option. Worth checking.
4helpful
2answers
Sony KP-41T65
is there a cadence to the blinking timer light?
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
